How to use widgets on your Apple iPad (9th Generation)
Press Edit.
Press the required widget.
Press Add Widget.
Press Done.
Press Edit.
Press Smart Stack.
Press Add Widget.
Press Done.
Press Done.
Press Edit Stack.
Your tablet can control which widgets to display based on factors such as time, GPS position or your activity.
Press Done.
Press Remove.
Press Done.
