How to select lock screen settings on your Apple iPad (11th Generation)
You can set several lock screens on your tablet and select different settings for them, such as background image, widgets and focus mode.
Press Add.
Press Focus.
You can set your tablet to use a specific lock screen with a specific focus mode.
Press the close icon.
Press the delete icon.
Press Delete This Wallpaper.
