The battery life on my Apple iPad (11th Generation) is short
Press Apps.
Press App Store.
Press Scheduled Summary.
Press Show Previews.
Press Screen Sharing.
Press Notification Grouping.
Press Mobile Data.
Press Battery.
Press General.
Press Background App Refresh.
