Ready to check out?
Check out now
How to use Gemini on your Google Pixel 9 Pro Fold
Gemini allows you to use many of your phone's functions in a smarter and more efficient way. To use most of the Gemini functions, you need to activate your Google account on your phone and select Gemini as your primary voice control assistant.
